Salta al contenuto principale
IBM ThinkPad R40 Keyboard Keys Replacement
Cosa ti serve
  1. IBM ThinkPad R40 Keyboard Keys Replacement, Disconnection: passo 1, immagine 1 di 1
    • Make sure your laptop is off and disconnected from the power source to ensure safety for yourself.
  2. IBM ThinkPad R40 Keyboard Keys Replacement, Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Locate the key that needs replacing. Use tweezers to slowly pull the key off the keyboard. Doing this will expose the underside of the keyboard.
  3. IBM ThinkPad R40 Keyboard Keys Replacement, Set aside: passo 3, immagine 1 di 1
    • Step 3: Set the old key aside and have the new key ready to be inserted onto the computer. The key has three parts, which you can see here.
  4. IBM ThinkPad R40 Keyboard Keys Replacement, Moving inside: passo 4, immagine 1 di 1
    • The new key will have an empty slot where they key used to be. It contains a small rubber spring. After the rubber spring is inserted take the new key and line it up according to the color springs on the backside of the key along with the keyboard.
  5. IBM ThinkPad R40 Keyboard Keys Replacement, Lining up: passo 5, immagine 1 di 1
    • After lining the key up, the black and white pieces will line up.
  6. IBM ThinkPad R40 Keyboard Keys Replacement, Finishing up: passo 6, immagine 1 di 1
    • Step 6: The key should not be firmly locked into place and functioning normally.
Conclusione
Erin
Membro da: 09/08/11
231 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 21
Tutti i Tempi: 4,568
