Salta al contenuto principale
How to Tighten GEN 2 Wheelchair Wheels
Cosa ti serve
  1. How to Tighten GEN 2 Wheelchair Wheels, How to Tighten GEN 2 Wheelchair Wheels: passo 1, immagine 1 di 1
    • Inspect the chair to see which wheel is loose.
    • Tighten the outer bolt with a 19 mm socket wrench.
  2. How to Tighten GEN 2 Wheelchair Wheels: passo 2, immagine 1 di 1
    • Tighten the nut facing the inside of the chair with a 19 mm wrench.
Conclusione
If wheel does not feel properly secured, keep tightening the wheel in small amounts until the wheel is secure.
Cal Poly, Team 14-8, Maness Spring 2013 Membro di Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,873
