Introduzione
Is your disco ball making screechy noises instead of groovy beams? You probably need to grease up the gear to make that noise go away and bring back the jams. This guide will teach you how to get to the gear so you can grease it up and get back to partying!
Turn the device over so that the base is on top.
  • Turn the device over so that the base is on top.
Aggiungi Commento
Peel off the piece of metal that is glued to hold the two halves of the base together.
  • Peel off the piece of metal that is glued to hold the two halves of the base together.
  • You may need rubber cement to reapply the piece of metal when reassembling the device.
Aggiungi Commento
Unscrew the four 10mm Phillips head screws on the bottom of the device. Once the base is removed, the device should look as shown on the picture.
  • Unscrew the four 10mm Phillips head screws on the bottom of the device.
  • Once the base is removed, the device should look as shown on the picture.
Aggiungi Commento
Use a pair of tweezers to crush the sides of the wirenuts. The wirenuts are crimped to lock the wires in place. Usually the wires are just twisted into them.
  • Use a pair of tweezers to crush the sides of the wirenuts.
  • The wirenuts are crimped to lock the wires in place. Usually the wires are just twisted into them.
  • Pull all of the wires out of the wirenuts.
Aggiungi Commento
Separate the wires that belong to the motor. The wires should be small and black.
  • Separate the wires that belong to the motor.
  • The wires should be small and black.
  • Remove the motor.
Aggiungi Commento
Unscrew the two 10 mm philips head screws.
  • Unscrew the two 10 mm philips head screws.
  • Unscrew the center 14 mm philips head screw.
  • Remove the plastic piece stabilizing the gear.
Aggiungi Commento
Apply oil to the gear directly from the oil bottle or with a Q-tip.
  • Apply oil to the gear directly from the oil bottle or with a Q-tip.
Aggiungi Commento
Conclusione
Nick Kaprielian
Membro da: 14/01/2014
495 Reputazione
4 Guide realizzate
Cal Poly, Team 17-3, Forte Winter 2014 Membro di Cal Poly, Team 17-3, Forte Winter 2014
CPSU-FORTE-W14S17G3
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 494
