Introduzione
Outline what you are going to teach someone how to do.
Unscrew the four Torx screws from the backplate.
  • Unscrew the four Torx screws from the backplate.
  • The backplate may begin to separate from the keypad face. Do not try to remove it yet.
  • The screws are T5 Torx screws, 5.6mm.
Aggiungi Commento
Swivel the phone open.
  • Swivel the phone open.
Aggiungi Commento
Using the Spudger, gently pry up the U-shaped grey cover below the keypad.
  • Using the Spudger, gently pry up the U-shaped grey cover below the keypad.
  • The cover is secured with adhesive tape. The gentler this is removed, the easier it will be to reassemble.
Aggiungi Commento
Remove the two Torx screws from below the cover.
  • Remove the two Torx screws from below the cover.
  • These are T5 Torx screws, 8.6mm.
Aggiungi Commento
Gently work a spudger or a fingernail between the keypad face and the backplate.
  • Gently work a spudger or a fingernail between the keypad face and the backplate.
  • The pieces are clipped together most tightly at the bottom loop section.
Aggiungi Commento
Separate the keypad face from the backplate. The keypad keys and the button component are both loose inside the phone, so take note of their orientation in case they become dislodged.
  • Separate the keypad face from the backplate.
  • The keypad keys and the button component are both loose inside the phone, so take note of their orientation in case they become dislodged.
  • Take note of the braided cord's state. Upon reassembly it should be returned to the same orientation.
Aggiungi Commento
Holding the backplate away from the swivel, remove the 4 small Phillips screws and both stamped struts from the swivel assembly. Note that only the bottom strut has a tab. The screws are Phillips, 2.9mm
  • Holding the backplate away from the swivel, remove the 4 small Phillips screws and both stamped struts from the swivel assembly.
  • Note that only the bottom strut has a tab.
  • The screws are Phillips, 2.9mm
Aggiungi Commento
The back housing is now disassembled, and the swivel assembly is revealed.
  • The back housing is now disassembled, and the swivel assembly is revealed.
Aggiungi Commento
Tighten the four small Phillips screws.
  • Tighten the four small Phillips screws.
  • The swivel assembly should now be less wobbly and loose, improving the function of the phone.
  • The screws are Phillips, 2.4mm.
Aggiungi Commento
Conclusione
Beau Blanchard
Membro da: 30/09/2012
20 Reputazione
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 423
