Introduzione
Nothing special, just to open the level pilot and repair it.
Strumenti
Parti
Nessuna parte richiesta.
The bottom rubber base can be removed
  • The bottom rubber base can be removed
Aggiungi Commento
Spray the small opening there with some multi-purpose oil.
  • Spray the small opening there with some multi-purpose oil.
Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
Alpha Dimension
Membro da: 09/09/2014
292 Reputazione
1 Guida realizzata
Not a good idea. Oil will &&^& it up dah.
stevenowlbassett - Replica
DeOxit (contact cleaner designed specifically for potentiometers) is what most people are recommending, not WD40 or dielectric grease..
Preferably DeOxit Gold, or at least not their (Hosa's) Fader Lube.
mystiphysician - Replica
Yes, use DeOxit or some similar contact cleaner
Eng Wei Chua - Replica
That knob became scratchy after some use. Cramolin contaclean helped, as always. Thanks for the teardown guide.
Daniel Leonov - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 67
Tutti i Tempi: 2,807
