Introduzione
This guide will help you to remove the cover plates from your Canon digital camera.
Parti
Nessuna parte richiesta.
Using a Tri-Wing screwdriver #0, remove the screws from the sides of the camera. There are two on each side, and two on the bottom plate. There are two on each side, and two on the bottom plate.
  • Using a Tri-Wing screwdriver #0, remove the screws from the sides of the camera.
    • There are two on each side, and two on the bottom plate.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Gently grip and remove the side cover while holding the Mini-USB cover open. Gently grip and remove the side cover while holding the Mini-USB cover open.
  • Gently grip and remove the side cover while holding the Mini-USB cover open.
Aggiungi Commento
Grip the camera from the sides and carefully remove the screen cover. Start at the bottom edge and slowly lift up the cover. Pay special attention to the area with the camera/video switch. While still gripping the sides, remove the front cover. Again, start at the bottom edge and slowly lift up the cover. Once you are done with the screen cover, remove the screw by the power switch that is anchoring the side plate and the sides will come off. While still gripping the sides, remove the front cover. Again, start at the bottom edge and slowly lift up the cover. Once you are done with the screen cover, remove the screw by the power switch that is anchoring the side plate and the sides will come off.
  • Grip the camera from the sides and carefully remove the screen cover. Start at the bottom edge and slowly lift up the cover. Pay special attention to the area with the camera/video switch.
    • While still gripping the sides, remove the front cover. Again, start at the bottom edge and slowly lift up the cover. Once you are done with the screen cover, remove the screw by the power switch that is anchoring the side plate and the sides will come off.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Stanley
Membro da: 30/01/2011
369 Reputazione
4 Guide realizzate
Cal Poly, Team 4-33, Regan Winter 2011 Membro di Cal Poly, Team 4-33, Regan Winter 2011
CPSU-REGAN-W11S4G33
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 4,878
