Salta al contenuto principale
How to clean your Panasonic SA-HT810V VCR heads
Cosa ti serve
  1. How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: passo 1, immagine 1 di 3 How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: passo 1, immagine 2 di 3 How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: passo 1, immagine 3 di 3
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Remove the screw that is on the right side of the panel facing you.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
  2. How to clean your Panasonic SA-HT810V VCR heads: passo 2, immagine 1 di 2 How to clean your Panasonic SA-HT810V VCR heads: passo 2, immagine 2 di 2
    • Rotate the device so that the back faces you.
    • With a phillips head screwdriver, locate and remove the 12 screws highlighted by the red circles in image one.
  3. How to clean your Panasonic SA-HT810V VCR heads: passo 3, immagine 1 di 1
    • Before removing cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. How to clean your Panasonic SA-HT810V VCR heads: passo 4, immagine 1 di 3 How to clean your Panasonic SA-HT810V VCR heads: passo 4, immagine 2 di 3 How to clean your Panasonic SA-HT810V VCR heads: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Microfiber Cleaning Cloths
    $3.99
    Compra
    • Before cleaning the VCR heads, be sure that the front of the device is facing you with the top cover removed.
    • Locate the two VCR heads highlighted in by the blue boxes in image one.
    • GENTLY clean heads with a microfiber rag and a cleaning solution of your choice.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 16-5, Maness Spring 2010 Membro di Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,697
