Introduzione
Cleaning the cartridge slot will fix most of the problems with the Nintendo 64.
Strumenti
Parti
Nessuna parte richiesta.
Open the slot with your finger.  Blow along the length of the cartridge slot with the air duster.
  • Open the slot with your finger. Blow along the length of the cartridge slot with the air duster.
Aggiungi Commento
Moist the q-tip with rubbing alcohol.  Rub it along the length of the cartridge slot.
  • Moist the q-tip with rubbing alcohol. Rub it along the length of the cartridge slot.
I never knew about this step, up until now i was just doing step one
Mike Chang - Replica
Alcohol is not going to "shine up" the pin. The secret will take 10 seconds!!!!. A worn out paper fingernail file .. I have never had a console brought back in 2 yrs
thegamestorems - Replica
What type brand of fingernail file?
Bresee -
Nice idea-- i was wondering what would fit in there between the contacts and not be too stiff so as to break anything but still offer just enough resistance and abrasion. I will surely give this a try.
Kevin K -
Conclusione
Altre 17 persone hanno completato questa guida.
tonymag28
Membro da: 28/10/2009
1.536 Reputazione
3 Guide realizzate
Cal Poly, Team 5-4, Regan Fall 2009 Membro di Cal Poly, Team 5-4, Regan Fall 2009
CPSU-REGAN-F09S5G4
7 Membri
6 Guide realizzate
Oh, my God! I really didn't think the alcohol thing would work (actually, I thought it was going to scr#w my nintendo), but it did! Thank u so much!
silvestrerenata - Replica
I'm a Iittle skeptic to use rubbing alcohol on my N64 system and games are you 100% sure it works and won't give me any problems downs the road.
James Hernandez -
You should use isopropyl alcohol, it’s 90% alcohol and drys very quickly. I usually dunk a q-tip in, tap it against the bottle to remove any excess, then clean the surface. As long as your not pouring the alcohol directly onto your electronics you’ll be fine.
Adam -
This was great!
notoriousVKC - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 16
Ultimi 7 Giorni: 141
Ultimi 30 Giorni: 561
Tutti i Tempi: 35,694
