Salta al contenuto principale
How to Clean a Canon PowerShot SD780 IS Shutter Button
Cosa ti serve
  1. How to Clean a Canon PowerShot SD780 IS Shutter Button, How to Clean a Canon PowerShot SD780 IS Shutter Button: passo 1, immagine 1 di 1
    • Before starting, make sure to turn off the camera and remove the battery.
  2. How to Clean a Canon PowerShot SD780 IS Shutter Button: passo 2, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the five outermost screws from the camera.
  3. How to Clean a Canon PowerShot SD780 IS Shutter Button: passo 3, immagine 1 di 1
    • Remove the front panel of the camera case to expose the top left ribbon cable. Pull the ribbon cable gently to disconnect it from the camera.
  4. How to Clean a Canon PowerShot SD780 IS Shutter Button: passo 4, immagine 1 di 1
    • Using a Phillips #00 screwdriver remove the single screw on the far left-hand side towards the bottom of the camera.
  5. How to Clean a Canon PowerShot SD780 IS Shutter Button: passo 5, immagine 1 di 1
    • Carefully pull the case apart to separate the 2 pieces.
    • The case will detach from the camera in two pieces.
  6. How to Clean a Canon PowerShot SD780 IS Shutter Button: passo 6, immagine 1 di 1
    • Remove the two screws on the metal plate of the camera case. This will give you access to the spring inside the metal plate for further cleaning.
    • Clean the inside of the camera with a cloth to remove dust and excess grime. This should unstick the shutter button and allow for full function.
Conclusione
Arlene Ale
Membro da: 03/13/14
455 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 20
Tutti i Tempi: 837
