Introduzione
Like all graphics cards, the Radeon X1900 XTX occasionally needs to be opened up and cleaned in order to function properlly.
Once you remove the heat sink, you'll need to reapply thermal paste to the GPU die. Follow our Applying Thermal Paste Guide for detailed directions.
Start by removing the card from the PC if you haven't already. Start by removing the card from the PC if you haven't already.
  • Start by removing the card from the PC if you haven't already.
Aggiungi Commento
The fan's power cable is located towards the bottom-left of the card. Disconnect the cable from the card. The cable and its connector on the X1900 are fragile.  Be careful, and try not to use excessive force when removing it.
  • The fan's power cable is located towards the bottom-left of the card.
  • Disconnect the cable from the card.
  • The cable and its connector on the X1900 are fragile. Be careful, and try not to use excessive force when removing it.
Aggiungi Commento
Removing the heatsink from the card: The clamp is held on by four small Phillips screws.  Remove them, then the clamp. Remove the four phillips screws surrounding the clamp.
  • Removing the heatsink from the card:
  • The clamp is held on by four small Phillips screws. Remove them, then the clamp.
  • Remove the four phillips screws surrounding the clamp.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Seperate the heatsink and the card.
  • Seperate the heatsink and the card.
if you're doing this on a Mac, you have to take out the two small screws on the dvi connection end and loosen the dvi connection nuts so the heatsink will separate.
Matt Kennedy - Replica
Replacing Thermal Paste: Using a Q-tip/cotton swab and rubbing alcohol, clean the copper plate that protrudes from the bottom of the heatsink.
  • Replacing Thermal Paste:
  • Using a Q-tip/cotton swab and rubbing alcohol, clean the copper plate that protrudes from the bottom of the heatsink.
Aggiungi Commento
Removing the heatsink's plastic cover: Remove these Phillips screws.
  • Removing the heatsink's plastic cover:
  • Remove these Phillips screws.
  • Seperate the plastic cover from the metal heat sink.
Aggiungi Commento
Cleaning dust out of the heat sink: Using a cotton swab/q-tip, clean the edges of the heat sink.  You can also use canned air if available.
  • Cleaning dust out of the heat sink:
  • Using a cotton swab/q-tip, clean the edges of the heat sink. You can also use canned air if available.
Aggiungi Commento
Using the same method that you used to clean the copper plate, clean the surface of the GPU die. Using the same method that you used to clean the copper plate, clean the surface of the GPU die.
  • Using the same method that you used to clean the copper plate, clean the surface of the GPU die.
Aggiungi Commento
  • Re-Applying Thermal Paste:
  • Apply a small glob of thermal paste to the corner of the die, (I recommend using Arctic Silver 5) and use an index card to spread a thin, even layer of it over the surface of the chip.
  • For more detailed directions, follow our Applying Thermal Paste Guide.
Aggiungi Commento
Conclusione
Altre 11 persone hanno completato questa guida.
Chris Green
Membro da: 11/10/2009
31.845 Reputazione
46 Guide realizzate
Master Techs Membro di Master Techs
Community
276 Membri
718 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 44
Tutti i Tempi: 11,014
