Introduzione
Over time dust and condensate may start to gather on the lens that is between the displayed image in the viewfinder and the eyepiece. To return the image in the viewfinder, this quick guide gives a method to clean the lens if dust gathers, and if water condensate gathers on the inner eyepiece lens.
Parti
Nessuna parte richiesta.
Lift viewfinder to access battery pack.
  • Lift viewfinder to access battery pack.
Aggiungi Commento
Press the battery release button. While pushing the battery button, slide the battery to the left.
  • Press the battery release button.
  • While pushing the battery button, slide the battery to the left.
Aggiungi Commento
Pull the battery pack out of the video camera.
  • Pull the battery pack out of the video camera.
Aggiungi Commento
Pull the viewfinder eyepiece out and away from the main video camera until the black mark appears.
  • Pull the viewfinder eyepiece out and away from the main video camera until the black mark appears.
Aggiungi Commento
Twist the eyepiece counterclockwise until it stops.
  • Twist the eyepiece counterclockwise until it stops.
Aggiungi Commento
Pull the eyepiece completely off  away from the rest of the viewfinder.
  • Pull the eyepiece completely off away from the rest of the viewfinder.
Aggiungi Commento
Using the Small Plastic Opening tool, pry the tab on the plastic lens away from the viewfinder. Using the Small Plastic Opening tool, pry the tab on the plastic lens away from the viewfinder.
  • Using the Small Plastic Opening tool, pry the tab on the plastic lens away from the viewfinder.
Aggiungi Commento
Use a cleaning cloth to wipe away residue from the viewfinder.
  • Use a cleaning cloth to wipe away residue from the viewfinder.
Aggiungi Commento
Conclusione
Kevin
Membro da: 24/01/2011
232 Reputazione
3 Guide realizzate
Cal Poly, Team 11-25, Maness Winter 2011 Membro di Cal Poly, Team 11-25, Maness Winter 2011
CPSU-MANESS-W11S11G25
4 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,828
