Salta al contenuto principale
How to clean Non-functoning buttons on remote
Cosa ti serve
  1. How to clean Non-functoning buttons on remote, How to clean Non-functoning buttons on remote: passo 1, immagine 1 di 1
    • For later testing: X marks butttons which still work, O marks buttons that don't.
  2. How to clean Non-functoning buttons on remote: passo 2, immagine 1 di 2 How to clean Non-functoning buttons on remote: passo 2, immagine 2 di 2
    • Open battery housing and remove the batteries
    • Remove the screw located in the center of the battery housing
  3. How to clean Non-functoning buttons on remote: passo 3, immagine 1 di 1
    • Top and bottom shell of the remote are held together by 4 latches per side. The most fore and aft ones are located about 1cm from each end
    • Pry them open with a small flat head. If you're carefull that will leave only tiny scratches, but it does take some force
  4. How to clean Non-functoning buttons on remote: passo 4, immagine 1 di 2 How to clean Non-functoning buttons on remote: passo 4, immagine 2 di 2
    • Once open, remove the insides and clean them from all the drinks and what not that has been poored over the remote
    • If necessary, add contact spray or alike to the buttom of the rubber buttons
  5. How to clean Non-functoning buttons on remote: passo 5, immagine 1 di 1
    • After cleaning and before full re-assembly, you might want to try if things improved.
    • Put the cicruit board back in, add batteries and put the rubber mats onto the circuit board
    • If the repair worked, you should the red top LED flashing
    • Put it all back together again. (Don't forget the screw in the battery housing.)
    • You might need some new batteries as well
Conclusione
Altre 22 persone hanno completato questa guida.
andre
Membro da: 03/12/12
1.701 Reputazione
4 Guide realizzate
29 Commenti
Having trouble with the latches. Can you explain the technique you used to pry them open?
Thanks!
bob - Replica
Hi Bob. Force, brute force. Sorry, I don't have a better advice for you. ;-)
andre -
thanks, I fixed mine using your guide.
surfer - Replica
You are a life saver, just fixed my onkyo RC-737m control with this guide... Broken a plastic clip but can't tell when it's back together. Cheers again! Leon
Leon Parsons - Replica
Géniaaaaaaaaaaal!
Deux télécommandes dont les boutons du volume ne répondaient plus! Et hop c'est revenu ;-)
Merciiiiiiii
Thierry Paulet - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 45
Tutti i Tempi: 37,501
