Introduzione
This guide shows how to properly clean and maintain the Nokia 3120. This guide disassembles the front cover of the Nokia 3120 and shows how to clean the face plate.
Strumenti
Parti
Nessuna parte richiesta.
Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone.
  • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
Aggiungi Commento
Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out.  This can be done with your finger-nail or a prying tool.
  • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
Aggiungi Commento
Using your fingernails or another tool, pry the front face plate out along its edges and corners. Using your fingernails or another tool, pry the front face plate out along its edges and corners. Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
Aggiungi Commento
If dirt has gotten inside the phone, both the lens and the case should be cleaned.
  • If dirt has gotten inside the phone, both the lens and the case should be cleaned.
  • Once the screen is exposed, spray cleaning solution onto a soft cloth and wipe the screen.
  • Make sure to thoroughly dry the screen.
Aggiungi Commento
Repeat the cleaning process on the clear plastic connected to the face-plate.
  • Repeat the cleaning process on the clear plastic connected to the face-plate.
    • If the screen still appears dirty after a thorough cleaning, parts may have to be replaced. See the troubleshooting guide.
Aggiungi Commento
Conclusione
Rashmili Vemula
Membro da: 11/03/2013
11 Reputazione
2 Guide realizzate
Clemson, Team 13-2, Benson Spring 2013 Membro di Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
3 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 544
