Introduzione
If your drive is having problems reading or writing a disk, dust may have collected on the lens, which will need to be cleaned.
Insert an open paper clip into the small hole on the left side of the faceplate. The tray should click open, extend it fully.
  • Insert an open paper clip into the small hole on the left side of the faceplate.
  • The tray should click open, extend it fully.
Aggiungi Commento
Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
  • Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
Aggiungi Commento
Pull the faceplate away from the main chassis.
  • Pull the faceplate away from the main chassis.
Aggiungi Commento
Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
  • Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
Aggiungi Commento
Lift the top and bottom chassis straight up in order to remove them. Lift the top and bottom chassis straight up in order to remove them.
  • Lift the top and bottom chassis straight up in order to remove them.
Aggiungi Commento
Clean the lens. Clean the lens.
  • Clean the lens.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
aaa
Membro da: 20/10/2011
165 Reputazione
2 Guide realizzate
What is the best fluid for the cleaning step?
lordchickenhawk - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 24
Tutti i Tempi: 4,552
