Parti
Nessuna parte richiesta.
Open the tray by pressing the eject button Remove the DVD tray faceplate by pushing the faceplate up off of the tray. Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  • Open the tray by pressing the eject button
  • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
Aggiungi Commento
Press the eject button to insert the tray
  • Press the eject button to insert the tray
  • After the tray is closed unplug DVD player
Aggiungi Commento
Unscrew the 3 screws in the back.
  • Unscrew the 3 screws in the back.
Aggiungi Commento
Pull the outer case upward and then towards you. Pull the outer case upward and then towards you.
  • Pull the outer case upward and then towards you.
Aggiungi Commento
There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate.
  • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
Aggiungi Commento
Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously. Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
Aggiungi Commento
Locate the white clip that attaches the cord to the motherboard Grasp clip and squeeze to release Lift up and remove power cord
  • Locate the white clip that attaches the cord to the motherboard
  • Grasp clip and squeeze to release
  • Lift up and remove power cord
  • Slide cord mount from outer case
Aggiungi Commento
Remove the three screws holding in the DVD tray Remove the three screws holding in the DVD tray Remove the three screws holding in the DVD tray
  • Remove the three screws holding in the DVD tray
Aggiungi Commento
Remove the power cord and first two ribbons by pulling them directly out of their sockets. Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
Aggiungi Commento
Gently lift the DVD tray off of the motherboard. Gently lift the DVD tray off of the motherboard.
  • Gently lift the DVD tray off of the motherboard.
Aggiungi Commento
Use the tweezers to make sure all the buttons aren't stuck.
  • Use the tweezers to make sure all the buttons aren't stuck.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Mitchell Hart
Membro da: 21/01/2011
819 Reputazione
5 Guide realizzate
Cal Poly, Team 3-30, Regan Winter 2011 Membro di Cal Poly, Team 3-30, Regan Winter 2011
CPSU-REGAN-W11S3G30
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,211
