Parti
Nessuna parte richiesta.
Using a Philips screwdriver, remove the two screws on the top of the device, towards the back.
  • Using a Philips screwdriver, remove the two screws on the top of the device, towards the back.
Aggiungi Commento
Remove the plastic cover by pulling up on the back and away from the faceplate. Remove the plastic cover by pulling up on the back and away from the faceplate.
  • Remove the plastic cover by pulling up on the back and away from the faceplate.
Aggiungi Commento
Remove the faceplate by unclipping the latches on the bottom of the device. Once it's unlatched, pull the faceplate off. Once it's unlatched, pull the faceplate off.
  • Remove the faceplate by unclipping the latches on the bottom of the device.
  • Once it's unlatched, pull the faceplate off.
Aggiungi Commento
Now that the device is open, you can check for any blown fuses that may need to be replaced.
  • Now that the device is open, you can check for any blown fuses that may need to be replaced.
Aggiungi Commento
Conclusione
Taryn
Membro da: 15/09/2011
103 Reputazione
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 764
