Introduzione
The device's power cord breaks easily, stopping it from delivering power to the device. In this guide, we will test for power by using a voltmeter.
Make sure the device is unplugged before beginning disassembly!
  • Make sure the device is unplugged before beginning disassembly!
  • Lift the lid and bowl from the top of the device.
Aggiungi Commento
Turn the device upside-down, so that the four legs of the device point upwards.
  • Turn the device upside-down, so that the four legs of the device point upwards.
Aggiungi Commento
Each of the four legs has a rubber cushion on its bottom. For each cushion, insert a plastic opening tool between the plastic leg and rubber cushion, and pry off the rubber cushion.
  • Each of the four legs has a rubber cushion on its bottom. For each cushion, insert a plastic opening tool between the plastic leg and rubber cushion, and pry off the rubber cushion.
Aggiungi Commento
Using a spanner screwdriver, remove the one 10mm long 7mm diameter spanner screw from the side of the brass panel.
  • Using a spanner screwdriver, remove the one 10mm long 7mm diameter spanner screw from the side of the brass panel.
Aggiungi Commento
Using a Phillips screwdriver, remove the 10mm long 7mm diameter Phillips-head screws from the inside of all four legs.
  • Using a Phillips screwdriver, remove the 10mm long 7mm diameter Phillips-head screws from the inside of all four legs.
  • The smaller leg at the bottom is now loose and not attached to the device. Set it aside.
Aggiungi Commento
Lift the brass plate off the device and set it aside.
  • Lift the brass plate off the device and set it aside.
Aggiungi Commento
Color coordinating wire groups make it easier to identify the wire groups during reassembly. Inside the device, there are three junctions with wires joined by Phillips-head screws. The first is connected to two wires, and the other two are connected to three wires each.
  • Color coordinating wire groups make it easier to identify the wire groups during reassembly.
  • Inside the device, there are three junctions with wires joined by Phillips-head screws. The first is connected to two wires, and the other two are connected to three wires each.
  • Unscrew the screw at the junction near the opposite side of the device from the front panel.
  • Label each of the two wires at this junction with a single color of tape.
Aggiungi Commento
Unscrew the screw at the junction just clockwise from the button panel. Label the three wires of this junction with tape of a second color.
  • Unscrew the screw at the junction just clockwise from the button panel.
  • Label the three wires of this junction with tape of a second color.
Aggiungi Commento
Unscrew the screw from the wire junction just behind the front panel. Label the three wires at this junction with a third color of tape.
  • Unscrew the screw from the wire junction just behind the front panel.
  • Label the three wires at this junction with a third color of tape.
Aggiungi Commento
During these steps, DO NOT touch the wires directly. You may be electrocuted.
  • During these steps, DO NOT touch the wires directly. You may be electrocuted.
  • Plug the device's power cord into a functioning outlet.
Aggiungi Commento
Locate the two wires which are connected directly to the power cord. Unlike the other wires, they are sheathed in a particularly thick, dot-textured plastic.
  • Locate the two wires which are connected directly to the power cord. Unlike the other wires, they are sheathed in a particularly thick, dot-textured plastic.
  • Make sure the voltmeter is on and set to a setting beween 120 and 500V. For most voltmeters the proper setting for this is the 200V setting.
  • Attach one of the voltmeter's probes to the metal portions of each of the two wires connected to the power cord's end on the device
  • The voltmeter should read a number significantly above 20V. A reading between 100 and 150 V indicates that the device is getting enough power. A lower number indicates the power cord is broken.
Aggiungi Commento
Conclusione
This guide alters no parts of the device, so no reassembly is needed from these steps.
Lillian Heng
Membro da: 26/09/2014
601 Reputazione
4 Guide realizzate
Cal Poly, Team 12-1, Forte Fall 2014 Membro di Cal Poly, Team 12-1, Forte Fall 2014
CPSU-FORTE-F14S12G1
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 704
