Salta al contenuto principale
How to align Razor A steering
Cosa ti serve
  1. How to align Razor A steering, How to align Razor A steering: passo 1, immagine 1 di 3 How to align Razor A steering, How to align Razor A steering: passo 1, immagine 2 di 3 How to align Razor A steering, How to align Razor A steering: passo 1, immagine 3 di 3
    • Locate the collar clamp near the base of the steering column.
    • Insert a 3/16" Allen wrench into the screw in the collar clamp and loosen it.
    • The collar clamp will be free to move and may slide around the steering column. When reassembling, return it to its original position.
  2. How to align Razor A steering: passo 2, immagine 1 di 2 How to align Razor A steering: passo 2, immagine 2 di 2
    • Firmly grasp the steering column and turn the wheel by hand.
    • View the scooter along the steering column. Be sure the wheel is perpendicular to the handlebars.
    • The second picture above shows a correct alignment of the steering column from this view.
Linea Traguardo
Altre 16 persone hanno completato questa guida.
Jordyn
Membro da: 10/09/12
544 Reputazione
5 Guide realizzate
Cal Poly, Team 9-13, Amido Fall 2012 Membro di Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Membri
10 Guide realizzate
4 Commenti
This is so unhelpful.
Linh Tran - Replica
Great guide! Thanks so much helped me to fix my old scooter and save approx. $50
Max Kittens - Replica
Wow, fixed all the kids scooters on the block….THANK YOU!!!!!
Kathy Earhart - Replica
It worked for me for a little, but after a while the fix stopped working and i am back to where i started, and it is now as tight as it will go. They should really make the scooters better. The guide was really helpful, so thanks so much!
Alan Weinberg - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 87
Tutti i Tempi: 29,762
