Salta al contenuto principale
How to adjust Triace A310 Brake Cable
Cosa ti serve
  1. How to adjust Triace A310 Brake Cable, How to adjust Triace A310 Brake Cable: passo 1, immagine 1 di 2 How to adjust Triace A310 Brake Cable, How to adjust Triace A310 Brake Cable: passo 1, immagine 2 di 2
    • While holding onto the brake cable, unscrew the screw that holds the brake cable in place using a 5mm allen wrench.
  2. How to adjust Triace A310 Brake Cable: passo 2, immagine 1 di 1
    • If you need to loosen your brakes, pull up on the arm while holding the brake cable in place.
    • To tighten your brakes follow the above step, except push down on the arm instead of pulling up.
  3. How to adjust Triace A310 Brake Cable: passo 3, immagine 1 di 1
    • Tighten the screw on the desired location along the cable with the same 5mm allen wrench.
Conclusione
You may need to repeat this process until your desired tension is achieved (trial and error).
Ben Hartinger
Membro da: 01/27/14
340 Reputazione
3 Guide realizzate
Cal Poly, Team 1-37, Maness Winter 2014 Membro di Cal Poly, Team 1-37, Maness Winter 2014
CPSU-MANESS-W14S1G37
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 268
