Salta al contenuto principale
How to adjust Razor A steering column
  1. How to adjust Razor A steering column, How to adjust Razor A steering column: passo 1, immagine 1 di 2 How to adjust Razor A steering column, How to adjust Razor A steering column: passo 1, immagine 2 di 2
    • Locate the tightening assembly. The tightening assembly consists of:
    • An upper nut
    • A lower nut
  2. How to adjust Razor A steering column: passo 2, immagine 1 di 1
    • This step refers to clockwise and counterclockwise rotation. This is as viewed from the top.
    • If loosening the steering column, follow these steps:
    • Turn the upper nut counterclockwise.
    • Turn the lower nut counterclockwise until it is tight against the upper nut.
    • If the steering column is still too tight, repeat the above two steps until reaching the desired steering column looseness.
    • If tightening the steering column, follow these steps:
    • Turn the lower nut clockwise until reaching the desired steering column tightness.
    • Turn the upper nut clockwise until it is tight against the lower nut.
Linea Traguardo
Altre 4 persone hanno completato questa guida.
Jordyn
Membro da: 10/09/12
544 Reputazione
5 Guide realizzate
Cal Poly, Team 9-13, Amido Fall 2012 Membro di Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Membri
10 Guide realizzate
8 Commenti
what move it with your hands? - didn't help
Heather McCasland - Replica
I couldn't turn this by hand. not sure who writes this advice. trying a pipe wrench.
jmackenzie1234 -
Thanks you! Why doesn't the owners manual have this?
Jessica - Replica
Thanks for the instructions. They helped me fix my son’s scooter.
That Dude - Replica
Thank you for showing the way how to adjust Razor scooter. This instruction help me to adjust my scooter.
Jessie Allen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 186
Tutti i Tempi: 40,963
