Introduzione
Reshaping the contact point electrodes which hold bObi's dustbin in place can resolve installation and bin latching difficulties.
Remove bObi's dustbin: Push down on the button found on bObi's back to release the dustbin. Push down on the button found on bObi's back to release the dustbin.
  • Remove bObi's dustbin:
    • Push down on the button found on bObi's back to release the dustbin.
Aggiungi Commento
Inside bObi are two contact point electrodes, secured with a small red fastener and two screws. Use a screwdriver to reach underneath the electrodes and pull upward gently to bend them back to the correct shape. Use a screwdriver to reach underneath the electrodes and pull upward gently to bend them back to the correct shape.
  • Inside bObi are two contact point electrodes, secured with a small red fastener and two screws.
  • Use a screwdriver to reach underneath the electrodes and pull upward gently to bend them back to the correct shape.
Aggiungi Commento
When the electrodes are fixed, slide the dustbin back into bObi. The HEPA filter side of the dustbin should face down. Ensure it locks in place, and the contact point electrodes will line up correctly, so bObi can resume functioning.
  • When the electrodes are fixed, slide the dustbin back into bObi. The HEPA filter side of the dustbin should face down.
  • Ensure it locks in place, and the contact point electrodes will line up correctly, so bObi can resume functioning.
Aggiungi Commento
Conclusione
Chelsea
Membro da: 24/09/2014
2.278 Reputazione
31 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 119
