Introduzione
There are a number of ways that you can reduce the occurrence of wheel bite with your skateboard. All of these ways can be used separately or together depending on your preference and need. This guide will show you how to perform the three most fundamental methods in order of how they would be installed together. Keep in mind you can pick and choose any of these methods at your discretion.
Cosa ti serve
When it comes to preventing wheel bite you may want to add a riser. This will occur during the truck installation process. If you have not started this process, get to step 3 in the Truck Installation guide and return here for your next step.
Now that you are just about ready to install your trucks, simply place the riser onto the hardware before the trucks. Return to the Truck Installation guide to finish installing the trucks.
To remove your risers, simply remove your trucks following the reverse directions of the Truck Installation guide. Follow steps of this guide in reverse to replace your old kingpin bushing.
Altre 5 persone hanno completato questa guida.
