Find the power cord.
  • Find the power cord.
  • Make sure that it is unplugged from the outlet. This is to make sure that no power is flowing through and you are not injured.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Check to make sure that the power cord is connected to the device. If it is not connect the smaller end to the back of the device.
  • Check to make sure that the power cord is connected to the device. If it is not connect the smaller end to the back of the device.
Aggiungi Commento
Check to make sure that the power cord is connected to an outlet. If not, take the two-pronged end and plug it in to an outlet. The device is now correctly plugged in.
  • Check to make sure that the power cord is connected to an outlet. If not, take the two-pronged end and plug it in to an outlet. The device is now correctly plugged in.
Aggiungi Commento
Conclusione
Cal Poly, Team 7-50, Forte Fall 2012 Membro di Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 194
