Introduzione
After 20 years of reliable service this great dryer still works, but now makes some awful noises while running. I'm replacing all the mechanical wear parts.
  • Obtain replacement parts. I found a mfr's parts list for my unit through a search. All parts that I wanted were available via Amazon. My entire bill with shipping was under $50.
Aggiungi Commento
  • Here are the tools I used. The riveter and snap ring pliers were bought new, since I've never owned those and I'm a tool collector.
Aggiungi Commento
  • Unplug the dryer. First clear a 2-3 feet of space in front of the dryer. You will be pulling large parts out of the front.
  • Use screwdriver to remove front of unit. Be careful to release wires from holding clips.
  • Now remove inner bulkhead, using nutdriver?
  • At idler pulley, work the belt loose from its drive and remove it from the dryer.
  • Dryer drum can now be removed. Gently lift it out of the dryer.
Aggiungi Commento
  • Locate both drum rollers in the dryer. See photo
  • Remove old drum roller. The bearings wear out in these. First remove the snap ring on the front of the shaft. Then pull off the roller.
  • Remove old drum roller shaft. These can get worn after years of use. They come off by twisting them counter-clockwise.
  • Install new shaft, drum roller, and snap ring. Repeat for other roller, since there are 2 in this unit.
Aggiungi Commento
  • Replace old idler pulley. These can get noisy and sticky as their bearings wear out.
  • Remove snap ring. Old pulley will come off. Inspect and clean the shaft. Install new pulley. Install snap ring.
  • I didn't replace my idler pulley tension spring, but if yours is broken or stretched, the part is Maytag #303945
Aggiungi Commento
  • Replace blower wheel. These crack and break after a few years' use.
  • Remove snap ring. Remove old wheel. Install new wheel. Install snap ring.
Aggiungi Commento
  • Replace front glides/pads. These parts reduce friction between the spinning drum and bulkhead. Over time they become less effective. They are inexpensive to replace and a good excuse to play with a riveter.
  • Drill out rivets of old glides. I used a ? bit. Pull up old glides.
  • Fit new pad and glide into place. Install with ? rivets that were included in kit.
  • Repeat for other glide location
Aggiungi Commento
  • Install drum back into dryer. Verify that it rolls smoothly on rollers.
  • Install new belt into dryer. See photo for proper belt path through the idler pulley.
  • Turn the drum a few times to verify belt will stay on path.
  • Reinstall bulkhead.
  • Reinstall front panel, taking care to tuck wiring back into clips.
  • Plug dryer back in and do a short test with a small load. Dryer should run nice and quiet now!
Aggiungi Commento
Conclusione
HoosierInPA
Membro da: 19/12/2013
128 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 87
Tutti i Tempi: 3,092
