Salta al contenuto principale
How to Fix Sticky Controls on a Logitech RumblePad2
Cosa ti serve
  1. How to Fix Sticky Controls on a Logitech RumblePad2, How to Fix Sticky Controls on a Logitech RumblePad2: passo 1, immagine 1 di 1
    • Remove the battery pack cover.
    • Remove the batteries.
  2. How to Fix Sticky Controls on a Logitech RumblePad2: passo 2, immagine 1 di 1
    • Remove the five screws from the back of the controller using the #0 Phillips screwdriver.
  3. How to Fix Sticky Controls on a Logitech RumblePad2: passo 3, immagine 1 di 2 How to Fix Sticky Controls on a Logitech RumblePad2: passo 3, immagine 2 di 2
    • Remove the back panel from the controller.
    • It is easiest to first pry off the panel from the bottom, as shown in the pictures.
    • If using a tool to pry the panel off, do not insert the tool far into the controller. This may damage the motherboard.
  4. How to Fix Sticky Controls on a Logitech RumblePad2: passo 4, immagine 1 di 1
    • Remove the two screws from the motherboard using the #0 Phillips screwdriver.
  5. How to Fix Sticky Controls on a Logitech RumblePad2: passo 5, immagine 1 di 2 How to Fix Sticky Controls on a Logitech RumblePad2: passo 5, immagine 2 di 2
    • Remove the rumble motors from their slots and allow them to hang freely.
    • Remove the motherboard from the controller by lifting up.
  6. How to Fix Sticky Controls on a Logitech RumblePad2: passo 6, immagine 1 di 1
    • Wipe the outer face of the analog sticks with a wet cotton swab or paper towel.
  7. How to Fix Sticky Controls on a Logitech RumblePad2: passo 7, immagine 1 di 1
    • Wipe the button pads with a wet cotton swab or paper towel.
  8. How to Fix Sticky Controls on a Logitech RumblePad2: passo 8, immagine 1 di 2 How to Fix Sticky Controls on a Logitech RumblePad2: passo 8, immagine 2 di 2
    • Remove the buttons from their slots by pushing them in from the front.
    • Wipe the buttons with a wet cotton swab or paper towel
Conclusione
After allowing the controller time to dry, reassemble your device by following these instructions in reverse order.
Dan Heckman
Membro da: 10/05/17
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 957
