Salta al contenuto principale
Hoover WindTunnel 2 Rewind Leaky Hose Replacement
Cosa ti serve
  1. Hoover WindTunnel 2 Rewind Leaky Hose Replacement, Leaky Hose: passo 1, immagine 1 di 1
    • Detach the top of the hose from the device by pressing the release button and pulling up on the hose.
  2. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: passo 2, immagine 1 di 1
    • Remove the other end of the hose by twisting the hose clockwise and pulling it off.
  3. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: passo 3, immagine 1 di 1
    • Firmly insert the larger end of the replacement hose into the upward facing hole in the vacuum.
  4. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: passo 4, immagine 1 di 1
    • Line up the smaller end of the hose and insert it into the downward facing hole.
    • Twist the hose until it locks.
Conclusione
The Hoover Windtunnel 2 Rewind must have a solid and functional hose to work correctly. With this set of instructions, it is easy to replace a leaky hose.
Altre 6 persone hanno completato questa guida.
Cal Poly, Team S11-G4, Banghart Winter 2018 Membro di Cal Poly, Team S11-G4, Banghart Winter 2018
CPSU-BANGHART-W18S11G4
5 Membri
10 Guide realizzate
6 Commenti
Good job, helpful. Thanks!
Celeste Williams-Hughes - Replica
Thanks, I'm stuck in quarantine and can't go out to get mine fixed, so I'm so glad I found this. Especially since it was just my hose being filled to the brim with dog hair!
Taylore Kirk - Replica
Same issue. Easy fix thanks!
mark camirand - Replica
That’s great instructions but it’s not even 8 months old. This has happened from day one!!
Linda Schindler - Replica
How long does it take to cool off and turn back on after removing the clog?
Victoria Tingwall - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 127
Tutti i Tempi: 27,911
