Salta al contenuto principale
Honeywell HY-204 Rotation Motor Replacement
Cosa ti serve
  1. Honeywell HY-204 Rotation Motor Replacement, Rotation Motor: passo 1, immagine 1 di 1
    • Before you begin, be sure to unplug the fan.
    • Lay fan on the ground and use your fingers peel the three feet off the bottom of the fan.
  2. Honeywell HY-204 Rotation Motor Replacement: passo 2, immagine 1 di 1
    • Remove the three 12mm screws using the Phillips #0 Screwdriver.
  3. Honeywell HY-204 Rotation Motor Replacement: passo 3, immagine 1 di 2 Honeywell HY-204 Rotation Motor Replacement: passo 3, immagine 2 di 2
    • Remove the two 10mm screws using the Phillips #0 Screwdriver.
  4. Honeywell HY-204 Rotation Motor Replacement: passo 4, immagine 1 di 1
    • Move the rotation motor left and right to reveal the screw connecting it to the fan.
    • Remove the 18mm screw from the side of the motor using the Phillips #0 Screwdriver.
  5. Honeywell HY-204 Rotation Motor Replacement: passo 5, immagine 1 di 1
    • Using the wire cutters, severe the wires connecting the rotation motor to the fan.
    • To put back together you will need to resolder or use wire connectors to reattach motor.
Conclusione
Cal Poly, Team 10-40, Amido Fall 2014 Membro di Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
3 Membri
7 Guide realizzate
2 Commenti
It seems that these instructions are on “How to eeplacr the oscillation motor". But they neglect the requirement to have a replacement motor or how/where to get the replacement motor. Otherwise the steps seem clear.
Alan A. Kopta - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,650
