Introduzione
After removing the outer casing, replacing the fan blades is quick and easy! You would want to use this guide to replace the broken part or clean dirty blades.
Remove the four 14 mm screws  from the back of the device using the Phillips #0 Screwdriver. Remove the four 14 mm screws  from the back of the device using the Phillips #0 Screwdriver.
  • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
Aggiungi Commento
Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force. Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
Aggiungi Commento
Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench. The nut uses a left-handed thread.
  • Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
  • The nut uses a left-handed thread.
Aggiungi Commento
Grasp the fan blade firmly and pull upward to remove it from the center column of the fan. The slots on the fan blades and center column need to be aligned for reassembly.
  • Grasp the fan blade firmly and pull upward to remove it from the center column of the fan.
  • The slots on the fan blades and center column need to be aligned for reassembly.
Aggiungi Commento
Conclusione
Jenna Johnson
Membro da: 14/10/2014
235 Reputazione
1 Guida realizzata
Cal Poly, Team 10-40, Amido Fall 2014 Membro di Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
3 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 111
Tutti i Tempi: 1,723
