Introduzione
This guide is necessary to complete before many of our other replacement guides, but it can also stand alone as a replacement guide for the control panel. This is a really simple guide and should only take you a few minutes!
Parti
Nessuna parte richiesta.
Remove the four 14 mm screws  from the back of the device using the Phillips #0 Screwdriver. Remove the four 14 mm screws  from the back of the device using the Phillips #0 Screwdriver.
  • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
Aggiungi Commento
Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force. Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
Aggiungi Commento
Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver. Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
  • Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
Aggiungi Commento
Pry off the control panel by forcefully lifting the tab located inside the front of the fan with the plastic opening tool.
  • Pry off the control panel by forcefully lifting the tab located inside the front of the fan with the plastic opening tool.
Aggiungi Commento
Conclusione
Nolan Ernotte
Membro da: 14/10/2014
363 Reputazione
3 Guide realizzate
Cal Poly, Team 10-40, Amido Fall 2014 Membro di Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
3 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 270
