Introduzione
Before you can fix anything inside of the Honeywell HY-204, you need to remove the case. Removing the case will require a bit of strength, but is pretty simple to do.
Cosa ti serve
Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
Altre 2 persone hanno completato questa guida.
