Salta al contenuto principale
Homelite UT44172 Safety Switch Replacement
Cosa ti serve
  1. Homelite UT44172 Safety Switch Replacement, Opening the device: passo 1, immagine 1 di 1
    • Remove the six 1.5 cm screws marked on the picture from the plastic casing with a Phillips #2 screwdriver.
  2. Homelite UT44172 Safety Switch Replacement, Remove Faceplate: passo 2, immagine 1 di 1
    • Remove the faceplate to expose the inner mechanisms.
  3. Homelite UT44172 Safety Switch Replacement, Switch Removal: passo 3, immagine 1 di 3 Homelite UT44172 Safety Switch Replacement, Switch Removal: passo 3, immagine 2 di 3 Homelite UT44172 Safety Switch Replacement, Switch Removal: passo 3, immagine 3 di 3
    • Remove the safety switch by pulling it away from the body of device.
    • Be careful not to lose the spring, which is under pressure and may fly out during removal.
  4. Homelite UT44172 Safety Switch Replacement, Spring Replacement: passo 4, immagine 1 di 1
    • Inspect both the spring and the switch to see if either is deformed or damaged. If so, replace the damaged part with a new part.
    • During reassembly, gently move the inner wires out of the way so they do not get caught in the spring.
Conclusione
Daniel Endericavillacis
Membro da: 01/25/15
101 Reputazione
1 Guida realizzata
USF Tampa, Team 17-5, Watkins Winter 2015 Membro di USF Tampa, Team 17-5, Watkins Winter 2015
USFT-WATKINS-W15S17G5
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 319
