Salta al contenuto principale
Headlight Bulb Replacement
Cosa ti serve
  1. Headlight Bulb Replacement, Headlight Bulb: passo 1, immagine 1 di 1
    • Before you begin, make sure you have the right bulb. I got this at the local autozone.
    • Do NOT touch the glass of the bulb. The oils from your fingers can drastically reduce the life of the bulb.
    • Vinyl or latex gloves are great if you have them available, but not required.
  2. Headlight Bulb Replacement: passo 2, immagine 1 di 2 Headlight Bulb Replacement: passo 2, immagine 2 di 2
    • Press firmly on the plugs clip and pull to remove the power cable from the bulb.
  3. Headlight Bulb Replacement: passo 3, immagine 1 di 3 Headlight Bulb Replacement: passo 3, immagine 2 di 3 Headlight Bulb Replacement: passo 3, immagine 3 di 3
    • Lift up and remove the metal wire cage holding the bulb in place.
  4. Headlight Bulb Replacement: passo 4, immagine 1 di 1
    • Remove the bulb by pulling it away from the headlight enclosure.
    • Once the old bulb is removed, take your new one and place it in the headlight.
    • Follow the steps in reverse to secure the new bulb in the headlight.
Conclusione
To replace the bulb, follow the steps in reverse order.
Tim Asp
Membro da: 01/24/11
4.005 Reputazione
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 3,446
