Introduzione
To replace the speaker the tools you will need are tweezers and a #00 Philips screwdriver.
Parti
Nessuna parte richiesta.
Place Visor Edge face down. Notice the tab connecting the flip cover to the back of the PDA.
  • Place Visor Edge face down.
  • Notice the tab connecting the flip cover to the back of the PDA.
  • Gently push tab forward.
  • Do not pull on the flip cover to try and remove it from the PDA.
Aggiungi Commento
Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
Aggiungi Commento
Remove the black plate from the PDA.
  • Remove the black plate from the PDA.
Aggiungi Commento
Remove four 2.6 mm Philips screws that are on the sides of the frame. Remove the remaining 3.9 mm Philips screw holding together the stylus holster and the frame.
  • Remove four 2.6 mm Philips screws that are on the sides of the frame.
  • Remove the remaining 3.9 mm Philips screw holding together the stylus holster and the frame.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the four 2.6 mm Philips screws on the top and bottom of the frame. Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
Aggiungi Commento
Remove the white frame from the PDA.
  • Remove the white frame from the PDA.
  • The frame may get stuck on the corners so be very gentle when working the corners off.
Aggiungi Commento
Pull off front cover gently.
  • Pull off front cover gently.
Aggiungi Commento
Remove buttons by hand, they should come off easily.
  • Remove buttons by hand, they should come off easily.
Aggiungi Commento
Pull off button board that was underneath buttons.
  • Pull off button board that was underneath buttons.
Aggiungi Commento
Use tweezers to pull speaker off.
  • Use tweezers to pull speaker off.
  • Pull speaker off by wire, pull down away from screen.
Aggiungi Commento
Conclusione
Nick Lazarakis
Membro da: 23/01/2011
331 Reputazione
3 Guide realizzate
Cal Poly, Team 11-28, Maness Winter 2011 Membro di Cal Poly, Team 11-28, Maness Winter 2011
CPSU-MANESS-W11S11G28
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 651
