Introduzione
Use this guide to replace the Motherboard.
Remove the outer screen cover by releasing  the top clip from the main body of the device. Remove the outer screen cover by releasing  the top clip from the main body of the device.
  • Remove the outer screen cover by releasing the top clip from the main body of the device.
Aggiungi Commento
Pull out the stylus from the top right corner of the device. Pull out the stylus from the top right corner of the device. Pull out the stylus from the top right corner of the device.
  • Pull out the stylus from the top right corner of the device.
Aggiungi Commento
Slide the memory cartridge cover up and off the device. Slide the memory cartridge cover up and off the device. Slide the memory cartridge cover up and off the device.
  • Slide the memory cartridge cover up and off the device.
Aggiungi Commento
Remove the battery cover by releasing the clip from the main body of the device. Remove the battery cover by releasing the clip from the main body of the device.
  • Remove the battery cover by releasing the clip from the main body of the device.
Aggiungi Commento
Remove the batteries from the device.
  • Remove the batteries from the device.
Aggiungi Commento
Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
  • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
  • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
Aggiungi Commento
Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device. Be careful while opening the casing as there is a flex strip connecting the two halves. Be careful while opening the casing as there is a flex strip connecting the two halves.
  • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
  • Be careful while opening the casing as there is a flex strip connecting the two halves.
Aggiungi Commento
Disconnect the flex strip from the motherboard with tweezers. Disconnect the flex strip from the motherboard with tweezers. Disconnect the flex strip from the motherboard with tweezers.
  • Disconnect the flex strip from the motherboard with tweezers.
Aggiungi Commento
Use tweezers to remove the power button from the back case.
  • Use tweezers to remove the power button from the back case.
Aggiungi Commento
Disconnect the button pad by using the spudger to pry it off the motherboard. Remove the button pad. Remove the button pad.
  • Disconnect the button pad by using the spudger to pry it off the motherboard.
  • Remove the button pad.
Aggiungi Commento
Unscrew the two 2.94mm Phillips #00 screws that hold the motherboard in place. Unscrew the two 2.94mm Phillips #00 screws that hold the motherboard in place.
  • Unscrew the two 2.94mm Phillips #00 screws that hold the motherboard in place.
Aggiungi Commento
Use the spudger to lift the motherboard from the case. Use the spudger to lift the motherboard from the case. Use the spudger to lift the motherboard from the case.
  • Use the spudger to lift the motherboard from the case.
Aggiungi Commento
Conclusione
David Faltemier
Membro da: 20/06/2012
19 Reputazione
5 Guide realizzate
Cal Poly, Team 1-2, Regan SU 2012 Membro di Cal Poly, Team 1-2, Regan SU 2012
CPSU-REGAN-SU12S1G2
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 695
