Salta al contenuto principale
Handspring Visor Deluxe PDA Back Cover Replacement
Cosa ti serve
  1. Handspring Visor Deluxe PDA Back Cover Replacement, Outside cover and stylus: passo 1, immagine 1 di 2 Handspring Visor Deluxe PDA Back Cover Replacement, Outside cover and stylus: passo 1, immagine 2 di 2
    • Remove the outer screen cover by releasing the top clip from the main body of the device.
  2. Handspring Visor Deluxe PDA Back Cover Replacement: passo 2, immagine 1 di 3 Handspring Visor Deluxe PDA Back Cover Replacement: passo 2, immagine 2 di 3 Handspring Visor Deluxe PDA Back Cover Replacement: passo 2, immagine 3 di 3
    • Pull out the stylus from the top right corner of the device.
  3. Handspring Visor Deluxe PDA Back Cover Replacement: passo 3, immagine 1 di 3 Handspring Visor Deluxe PDA Back Cover Replacement: passo 3, immagine 2 di 3 Handspring Visor Deluxe PDA Back Cover Replacement: passo 3, immagine 3 di 3
    • Slide the memory cartridge cover up and off the device.
  4. Handspring Visor Deluxe PDA Back Cover Replacement, Batteries: passo 4, immagine 1 di 2 Handspring Visor Deluxe PDA Back Cover Replacement, Batteries: passo 4, immagine 2 di 2
    • Remove the battery cover by releasing the clip from the main body of the device.
  5. Handspring Visor Deluxe PDA Back Cover Replacement: passo 5, immagine 1 di 1
    • Remove the batteries from the device.
  6. Handspring Visor Deluxe PDA Back Cover Replacement, Back Cover: passo 6, immagine 1 di 1
    • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
  7. Handspring Visor Deluxe PDA Back Cover Replacement: passo 7, immagine 1 di 3 Handspring Visor Deluxe PDA Back Cover Replacement: passo 7, immagine 2 di 3 Handspring Visor Deluxe PDA Back Cover Replacement: passo 7, immagine 3 di 3
    • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
    • Be careful while opening the casing as there is a flex strip connecting the two halves.
  8. Handspring Visor Deluxe PDA Back Cover Replacement: passo 8, immagine 1 di 3 Handspring Visor Deluxe PDA Back Cover Replacement: passo 8, immagine 2 di 3 Handspring Visor Deluxe PDA Back Cover Replacement: passo 8, immagine 3 di 3
    • Disconnect the flex strip from the motherboard with tweezers.
Conclusione
Robert
Membro da: 07/07/12
23 Reputazione
1 Guida realizzata
Cal Poly, Team 1-2, Regan SU 2012 Membro di Cal Poly, Team 1-2, Regan SU 2012
CPSU-REGAN-SU12S1G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 575
