Parti
Nessuna parte richiesta.
Identify the black air concentrating nozzle.
  • Identify the black air concentrating nozzle.
Aggiungi Commento
Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
  • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
Aggiungi Commento
Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
  • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
  • The purpose of this guide is to demonstrate the repair steps for a generic hair dryer. We do not specify screw sizes because screw sizes can differ between hair dryers. For most hair dryers, use a Phillips #1 Screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 Screwdriver.
Aggiungi Commento
Detach the hair dryer grating from the body by gently twisting the grating from side to side.
  • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
Aggiungi Commento
Separate the hair dryer grating into the three pieces seen in the image.
  • Separate the hair dryer grating into the three pieces seen in the image.
Aggiungi Commento
Conclusione
Mitch
Membro da: 04/10/2012
28 Reputazione
5 Guide realizzate
Cal Poly, Team 24-29, Regan Fall 2012 Membro di Cal Poly, Team 24-29, Regan Fall 2012
CPSU-REGAN-F12S24G29
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,312
