Introduzione
This guide describes the steps to separate the HTC myTouch motherboard from the glass screen for replacement or repair. This guide will require you to unscrew a T5 Torx screw with a VOID label. Unfastening this screw would void any warranty the phone may have.
Press each thumb on both sides of the upper corners and apply pressure downwards. Then, while still applying pressure, slide the back cover down.
  • Press each thumb on both sides of the upper corners and apply pressure downwards.
  • Then, while still applying pressure, slide the back cover down.
Aggiungi Commento
Remove the Battery. Remove the SIM card.
  • Remove the Battery.
  • Remove the SIM card.
Aggiungi Commento
Push the SD card in and the SD card should pop loose.
  • Push the SD card in and the SD card should pop loose.
  • Pull the SD card out.
Aggiungi Commento
Remove the four 6-mm T5 torx screws in the four corners. Remove the two 4-mm T5 torx screws in the middle.
  • Remove the four 6-mm T5 torx screws in the four corners.
  • Remove the two 4-mm T5 torx screws in the middle.
Aggiungi Commento
Use the existing gap, to dislodge the antenna cover from the phone. Pull out the antenna cover to have access to the motherboard.
  • Use the existing gap, to dislodge the antenna cover from the phone.
  • Pull out the antenna cover to have access to the motherboard.
Aggiungi Commento
Use a precision flathead screwdriver to dislodge the back plate from the phone by carefully inserting it into the slit between the frame and cover and pushing downward. Go around the edges of the phone, and continue to dislodge the back plate from the front part of the phone.
  • Use a precision flathead screwdriver to dislodge the back plate from the phone by carefully inserting it into the slit between the frame and cover and pushing downward.
  • Go around the edges of the phone, and continue to dislodge the back plate from the front part of the phone.
Aggiungi Commento
Remove the 3-mm Phillips head screw located on the side of the bottom left-hand corner of the phone. Remove the 3-mm Phillips head screw located on the top right-hand corner of the phone.
  • Remove the 3-mm Phillips head screw located on the side of the bottom left-hand corner of the phone.
  • Remove the 3-mm Phillips head screw located on the top right-hand corner of the phone.
  • Do not remove any of the screws located on the actual circuit boards.
Aggiungi Commento
Place a finger between the circuit board and the front cover, and lift up gently. Continue separating the circuit board from the front cover and screen and watch for a ribbon cable to detach. Finish separating the circuit board from the front panel.
  • Place a finger between the circuit board and the front cover, and lift up gently.
  • Continue separating the circuit board from the front cover and screen and watch for a ribbon cable to detach.
  • Finish separating the circuit board from the front panel.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Tony Tran
Membro da: 25/09/2012
351 Reputazione
3 Guide realizzate
Cal Poly, Team 2-9, Propen Fall 2012 Membro di Cal Poly, Team 2-9, Propen Fall 2012
CPSU-PROPEN-F12S2G9
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,293
