Introduzione
Takes you through the steps to install the speakers.
Remove the back case with your fingernail to expose the battery. (Not shown in picture) Pull the black tab to remove the battery.
  • Remove the back case with your fingernail to expose the battery. (Not shown in picture)
  • Pull the black tab to remove the battery.
Aggiungi Commento
Use a spudger to begin removal of the camera cover by inserting the flat end into the two notches and gently pry them up one at a time.
  • Use a spudger to begin removal of the camera cover by inserting the flat end into the two notches and gently pry them up one at a time.
Aggiungi Commento
Work the spudger around the edge of the camera cover to release the clips. Work the spudger around the edge of the camera cover to release the clips.
  • Work the spudger around the edge of the camera cover to release the clips.
Aggiungi Commento
  • Use a T5 Torx screwdriver to remove four 6mm screws that secure the back panel to the main body.
  • There is a screw under the "void" sticker.
Aggiungi Commento
Device rotated 180 degrees. Insert the flat end of a spudger into the crack between the front and rear cover.
  • Device rotated 180 degrees.
  • Insert the flat end of a spudger into the crack between the front and rear cover.
  • Once you have enough of a gap to fit a plastic opening tool into it, use the opening tool to release the clips.
Aggiungi Commento
Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge. Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge.
  • Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge.
Aggiungi Commento
Pull off the back case panel. Pull off the back case panel.
  • Pull off the back case panel.
Aggiungi Commento
Device rotated 180 degrees. Use the plastic opening tool to disconnect the speaker connections.
  • Use the plastic opening tool to disconnect the speaker connections.
Aggiungi Commento
Conclusione
Kyle Champ
Membro da: 03/10/2011
204 Reputazione
12 Guide realizzate
Cal Poly, Team 20-27, Maness Fall 2011 Membro di Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 633
