Salta al contenuto principale
HTC Wizard 200 Keypad Replacement
Cosa ti serve
  1. HTC Wizard 200 Keypad Replacement, Battery: passo 1, immagine 1 di 2 HTC Wizard 200 Keypad Replacement, Battery: passo 1, immagine 2 di 2
    • To expose the battery, remove the outer case with your fingernail.
    • Remove the battery by pulling the black tab.
  2. HTC Wizard 200 Keypad Replacement, Back Panel: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Spudger
    $3.99
    Compra
    • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
  3. HTC Wizard 200 Keypad Replacement: passo 3, immagine 1 di 2 HTC Wizard 200 Keypad Replacement: passo 3, immagine 2 di 2
    Spudger
    $3.99
    Compra
    • Work the spudger around the edges of the camera cover until it comes off.
  4. HTC Wizard 200 Keypad Replacement: passo 4, immagine 1 di 2 HTC Wizard 200 Keypad Replacement: passo 4, immagine 2 di 2
    T5 Torx Screwdriver
    $5.49
    Compra
    • Remove the four 6 mm screws with the T5 Torx screwdriver.
    • One of the screws is under the "void" sticker.
  5. HTC Wizard 200 Keypad Replacement: passo 5, immagine 1 di 3 HTC Wizard 200 Keypad Replacement: passo 5, immagine 2 di 3 HTC Wizard 200 Keypad Replacement: passo 5, immagine 3 di 3
    • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
    • Work the tool around the edges until all the clips release.
  6. HTC Wizard 200 Keypad Replacement: passo 6, immagine 1 di 2 HTC Wizard 200 Keypad Replacement: passo 6, immagine 2 di 2
    • Once all the clips are open, remove the inner panel from the phone.
  7. HTC Wizard 200 Keypad Replacement, Motherboard: passo 7, immagine 1 di 1
    Spudger
    $3.99
    Compra
    • Use the spudger to pry the camera off.
  8. HTC Wizard 200 Keypad Replacement: passo 8, immagine 1 di 2 HTC Wizard 200 Keypad Replacement: passo 8, immagine 2 di 2
    Compra
    • Using tweezers, flip the connector latch away from the motherboard.
    • Detach the flexible connection from under the connector latch.
  9. HTC Wizard 200 Keypad Replacement: passo 9, immagine 1 di 1
    • Slide the keyboard into the open position.
  10. HTC Wizard 200 Keypad Replacement: passo 10, immagine 1 di 2 HTC Wizard 200 Keypad Replacement: passo 10, immagine 2 di 2
    Spudger
    $3.99
    Compra
    • Lift the motherboard out of the case using the spudger.
    • Expose the underside of the motherboard using your hands.
  11. HTC Wizard 200 Keypad Replacement: passo 11, immagine 1 di 2 HTC Wizard 200 Keypad Replacement: passo 11, immagine 2 di 2
    • Remove the flexible connection from the motherboard.
    • Caution: Removing the connection too fast may cause damage to the connection and cables.
  12. HTC Wizard 200 Keypad Replacement, Keyboard Slider: passo 12, immagine 1 di 3 HTC Wizard 200 Keypad Replacement, Keyboard Slider: passo 12, immagine 2 di 3 HTC Wizard 200 Keypad Replacement, Keyboard Slider: passo 12, immagine 3 di 3
    T5 Torx Screwdriver
    $5.49
    Compra
    • Remove the four 5mm screws with the T5 Torx screwdriver.
    • Remove the keyboard slider from the main body.
  13. HTC Wizard 200 Keypad Replacement, Keypad: passo 13, immagine 1 di 2 HTC Wizard 200 Keypad Replacement, Keypad: passo 13, immagine 2 di 2
    • Use a screwdriver to remove eight 2mm Phillips screws that secure the keypad to the keyboard slider.
  14. HTC Wizard 200 Keypad Replacement: passo 14, immagine 1 di 2 HTC Wizard 200 Keypad Replacement: passo 14, immagine 2 di 2
    • Use the plastic opening tool to gently lift up the keypad.
Conclusione
Kyle Champ
Membro da: 10/03/11
225 Reputazione
12 Guide realizzate
Cal Poly, Team 20-27, Maness Fall 2011 Membro di Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Membri
24 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 683
