Salta al contenuto principale
HTC Vive Controller Battery Replacement
Cosa ti serve
  1. HTC Vive Controller Battery Replacement, Saucer Panels: passo 1, immagine 1 di 3 HTC Vive Controller Battery Replacement, Saucer Panels: passo 1, immagine 2 di 3 HTC Vive Controller Battery Replacement, Saucer Panels: passo 1, immagine 3 di 3
    • Turn over the Vive controller so that the bottom saucer is facing up.
    • Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
    Chiedi a FixBot
    Aggiungi Commento
  2. HTC Vive Controller Battery Replacement: passo 2, immagine 1 di 2 HTC Vive Controller Battery Replacement: passo 2, immagine 2 di 2
    • Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
    • Remove only the top saucer cover by pulling up with your hand.
    Chiedi a FixBot
    Aggiungi Commento
  3. HTC Vive Controller Battery Replacement: passo 3, immagine 1 di 2 HTC Vive Controller Battery Replacement: passo 3, immagine 2 di 2
    • Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
    Chiedi a FixBot
    Aggiungi Commento
  4. HTC Vive Controller Battery Replacement: passo 4, immagine 1 di 3 HTC Vive Controller Battery Replacement: passo 4, immagine 2 di 3 HTC Vive Controller Battery Replacement: passo 4, immagine 3 di 3
    • Carefully pull away the bottom saucer cover with your hand.
    • To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
    Chiedi a FixBot
    Aggiungi Commento
  5. HTC Vive Controller Battery Replacement, Front Panel: passo 5, immagine 1 di 2 HTC Vive Controller Battery Replacement, Front Panel: passo 5, immagine 2 di 2
    • Use the T5 Torx screwdriver to remove the two black 5.2mm screws on the back gray panel.
    Chiedi a FixBot
    Aggiungi Commento
  6. HTC Vive Controller Battery Replacement: passo 6, immagine 1 di 1
    • Turn over the Vive controller so that the exposed bottom saucer panel is facing up.
    • Use the T5 Torx screwdriver to remove the three black 5.2mm screws.
    Chiedi a FixBot
    Aggiungi Commento
  7. HTC Vive Controller Battery Replacement: passo 7, immagine 1 di 2 HTC Vive Controller Battery Replacement: passo 7, immagine 2 di 2
    • Use the nylon spudger to separate the front panel gently by running the spudger around the edges of the handle.
    • Only separate the front panel around the edges. Do not try to completely remove the panel yet.
    • Gently lift the right side of the panel to the left.
    Chiedi a FixBot
    Aggiungi Commento
  8. HTC Vive Controller Battery Replacement: passo 8, immagine 1 di 1
    • Disconnect the upper ribbon cable gently by pulling the ribbon up and away from the motherboard with two fingers.
    • Do not try to disconnect the ribbon cables from the front panel.
    Chiedi a FixBot
    Aggiungi Commento
  9. HTC Vive Controller Battery Replacement: passo 9, immagine 1 di 2 HTC Vive Controller Battery Replacement: passo 9, immagine 2 di 2
    • Disconnect the middle ribbon cable gently by pulling the ribbon cable up and away from the motherboard with two fingers.
    Chiedi a FixBot
    Aggiungi Commento
  10. HTC Vive Controller Battery Replacement: passo 10, immagine 1 di 3 HTC Vive Controller Battery Replacement: passo 10, immagine 2 di 3 HTC Vive Controller Battery Replacement: passo 10, immagine 3 di 3
    • Use the nylon spudger to lift the white tab by 90 degrees.
    • Disconnect the bottom ribbon cable gently by pulling the ribbon cable down with two fingers.
    Chiedi a FixBot
    Aggiungi Commento
  11. HTC Vive Controller Battery Replacement, Battery: passo 11, immagine 1 di 2 HTC Vive Controller Battery Replacement, Battery: passo 11, immagine 2 di 2
    • Use the Phillips 00 screwdriver to remove two black 2.8mm screws from the silver plate.
    • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the bottom right corner of the silver plate.
    Chiedi a FixBot
    Aggiungi Commento
  12. HTC Vive Controller Battery Replacement: passo 12, immagine 1 di 1
    • Remove the silver plate by pinching it with two fingers and lifting up.
    Chiedi a FixBot
    Aggiungi Commento
  13. HTC Vive Controller Battery Replacement: passo 13, immagine 1 di 1
    • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the top left of the battery frame.
    Chiedi a FixBot
    Aggiungi Commento
  14. HTC Vive Controller Battery Replacement: passo 14, immagine 1 di 2 HTC Vive Controller Battery Replacement: passo 14, immagine 2 di 2
    • Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the battery frame.
    Chiedi a FixBot
    Aggiungi Commento
  15. HTC Vive Controller Battery Replacement: passo 15, immagine 1 di 2 HTC Vive Controller Battery Replacement: passo 15, immagine 2 di 2
    • Disconnect the three-pin cable gently by pinching the cable with two fingers and pulling up.
    Chiedi a FixBot
    Aggiungi Commento
  16. HTC Vive Controller Battery Replacement: passo 16, immagine 1 di 3 HTC Vive Controller Battery Replacement: passo 16, immagine 2 di 3 HTC Vive Controller Battery Replacement: passo 16, immagine 3 di 3
    • Lift the battery frame to remove the battery from the Vive controller
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 34 persone hanno completato questa guida.
Cal Poly, Team S15-G5, Livingston Fall 2017 Membro di Cal Poly, Team S15-G5, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G5
4 Membri
51 guide realizzate
14Commenti sulla guida
well if theres no parts…then theres no point…
altimmons - Rispondi Condividi
So, where do I get a replacement battery from? Does anyone know the part number?
scotty - Rispondi Condividi
This helped me ALOT. i had a controller stop charging or powering on. Decided to use this guide to pull just pull power and re seed the connection for the battery. The Battery connection IS NOT CLIPPED IN. TAPE holds down the connection to the terminals. So it can easy come loose over jolts and shocks or normal use
Mike Moutrie - Rispondi Condividi
battery is 3.85vdc 960ma
HTC model boplh100
3.69Whr
Part number 35H00244-00M
guido - Rispondi Condividi
With all the comments and steps, I easily took apart and rebuilt my controller. Thank you!!
Also, I used this cheap repair kit they sell at walmart if you dont have the tools and don't want to order them online.
https://www.walmart.com/ip/Hyper-Tough-T...
A K - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 12
Ultimi 7 giorni: 85
Ultimi 30 giorni: 322
Tutti i Tempi: 48,952
