Introduzione
To replace keyboard.
Parti
Nessuna parte richiesta.
Gently press on back plate, push toward camera direction. Gently press on back plate, push toward camera direction.
  • Gently press on back plate, push toward camera direction.
Aggiungi Commento
Use finger to lift up an edge of battery. Use finger to lift up an edge of battery.
  • Use finger to lift up an edge of battery.
Aggiungi Commento
Remove 4 screws circled in red using T6 screw driver.
  • Remove 4 screws circled in red using T6 screw driver.
Aggiungi Commento
Lift plastic cover near Memory card slot. Lift plastic cover near Memory card slot.
  • Lift plastic cover near Memory card slot.
Aggiungi Commento
Remove two Phillips #00 screws from the backside of the screen.
  • Remove two Phillips #00 screws from the backside of the screen.
Aggiungi Commento
Insert a spudger or plastic opening tool into the seam on the side of the phone. Gently pry apart the two halves of the phone.
  • Insert a spudger or plastic opening tool into the seam on the side of the phone.
  • Gently pry apart the two halves of the phone.
  • Work your way around the phone until the two halves separate.
Aggiungi Commento
Gently unplug connectors marked with blue rectangle. Remove screws circled in red with 00 Phillip screw driver.
  • Gently unplug connectors marked with blue rectangle.
  • Remove screws circled in red with 00 Phillip screw driver.
Which screws in red? There aren't any.
Calion - Replica
They are marked up in red in the second picture.
Jake Devincenzi -
Gently lift logic board using plastic opener tool. Be aware of antenna
  • Gently lift logic board using plastic opener tool.
  • Be aware of antenna
Aggiungi Commento
Remove 4 screws circled in red using 00 Phillip screw driver. Remove 4 screws circled in red using 00 Phillip screw driver.
  • Remove 4 screws circled in red using 00 Phillip screw driver.
Aggiungi Commento
Conclusione
Zhaowei Zhang
Membro da: 28/04/2011
112 Reputazione
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,953
