Introduzione
If your HTC Touch Pro 2 Camera isn’t turning on, a possible issue may be with the camera lens. Follow this guide to learn how to replace your HTC Touch Pro 2 Camera. After the lens is replaced the quality of picture should be restored to its original state. This guide requires a T5 screwdriver and some tweezers.
Use caution when replacing the lens if the glass of the lens is shattered to avoid injury.
Cosa ti serve
Apply pressure and slide upward to remove back cover.
Lift the back cover up away from the phone.
Remove the four screws from the corners of the phone using a T5 Torx screwdriver.
