Introduzione
Warning: Always be sure you are grounded whenever handling any of the circuit or logic boards.
Remove the back panel by sliding it up.
  • Remove the back panel by sliding it up.
Aggiungi Commento
Remove the battery.
  • Remove the battery.
Aggiungi Commento
Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
  • Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
Aggiungi Commento
Use the plastic opening tool to remove the front panel from the phone. Unplug the front button cable from the inside of the phone.
  • Use the plastic opening tool to remove the front panel from the phone.
  • Unplug the front button cable from the inside of the phone.
Aggiungi Commento
Remove the 2 philips-head screws on the back of the front panel using the PH00 screwdriver.
  • Remove the 2 philips-head screws on the back of the front panel using the PH00 screwdriver.
Aggiungi Commento
Remove the small circuit board by gently pushing on the center button on the front of the phone.
  • Remove the small circuit board by gently pushing on the center button on the front of the phone.
Aggiungi Commento
Remove the buttons by pushing on them from the front side of the phone.
  • Remove the buttons by pushing on them from the front side of the phone.
Aggiungi Commento
Conclusione
Andrew Brooks
Membro da: 13/04/2011
101 Reputazione
2 Guide realizzate
Cal Poly, Team 15-12, Regan Spring 2011 Membro di Cal Poly, Team 15-12, Regan Spring 2011
CPSU-REGAN-S11S15G12
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,737
