Introduzione
Use this guide to replace a worn out or damaged rear panel on the HTC Thunderbolt.
Parti
Nessuna parte richiesta.
Insert the plastic opening tool into the top of the Thunderbolt near the power button.
  • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
  • Gently pry up on the rear panel around the edges until it is loose.
Aggiungi Commento
Lift and remove the rear panel.
  • Lift and remove the rear panel.
Aggiungi Commento
Conclusione
Cal Poly, Team 19-45, Regan Winter 2013 Membro di Cal Poly, Team 19-45, Regan Winter 2013
CPSU-REGAN-W13S19G45
4 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 270
