Introduzione
Use this guide to gain access to the motherboard of your HTC Thunderbolt. It is the main control for the entire phone.
Cosa ti serve
Insert the plastic opening tool into the top of the Thunderbolt near the power button.
Gently pry up on the rear panel around the edges until it is loose.
Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
Remove the battery from the inner frame.
Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
Using the tip of an plastic opening tool flip up the tab holding the capacitive button ribbon cable.
Use a pair of tweezers to pull the capacitive button cable out of its socket.
Altre 2 persone hanno completato questa guida.
