Salta al contenuto principale
HTC Thunderbolt MicroSD Card Replacement
Cosa ti serve
  1. HTC Thunderbolt MicroSD Card Replacement, Rear Panel: passo 1, immagine 1 di 1
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. HTC Thunderbolt MicroSD Card Replacement: passo 2, immagine 1 di 1
    • Lift and remove the rear panel.
  3. HTC Thunderbolt MicroSD Card Replacement, Battery: passo 3, immagine 1 di 2 HTC Thunderbolt MicroSD Card Replacement, Battery: passo 3, immagine 2 di 2
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  4. HTC Thunderbolt MicroSD Card Replacement, MicroSD Card: passo 4, immagine 1 di 2 HTC Thunderbolt MicroSD Card Replacement, MicroSD Card: passo 4, immagine 2 di 2
    • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
  5. HTC Thunderbolt MicroSD Card Replacement: passo 5, immagine 1 di 1
    • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
Conclusione
Vanessa
Membro da: 01/18/13
60 Reputazione
4 Guide realizzate
Cal Poly, Team 19-45, Regan Winter 2013 Membro di Cal Poly, Team 19-45, Regan Winter 2013
CPSU-REGAN-W13S19G45
4 Membri
24 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,411
