Salta al contenuto principale
HTC SMT 6175 Keyboard Replacement
Cosa ti serve
  1. HTC SMT 6175 Keyboard Replacement, Back Case: passo 1, immagine 1 di 1
    • First, flip the phone over so that the back is facing upwards.
  2. HTC SMT 6175 Keyboard Replacement: passo 2, immagine 1 di 2 HTC SMT 6175 Keyboard Replacement: passo 2, immagine 2 di 2
    • Using both thumbs, push the back side of the phone's exterior up and remove the front face of the phone.
  3. HTC SMT 6175 Keyboard Replacement, Battery: passo 3, immagine 1 di 2 HTC SMT 6175 Keyboard Replacement, Battery: passo 3, immagine 2 di 2
    • Insert your finger or a pry tool into the slot above the battery. Remove it and set aside.
  4. HTC SMT 6175 Keyboard Replacement, Keyboard: passo 4, immagine 1 di 2 HTC SMT 6175 Keyboard Replacement, Keyboard: passo 4, immagine 2 di 2
    • To remove the back casing inside the phone, remove the six screws around the perimeter.
  5. HTC SMT 6175 Keyboard Replacement: passo 5, immagine 1 di 2 HTC SMT 6175 Keyboard Replacement: passo 5, immagine 2 di 2
    • Carefully pull off the back casing.
    • This step may be difficult. Start pulling the back out from the front shell. As it starts to lift up, move the phone side-to-side until the whole back is free.
  6. HTC SMT 6175 Keyboard Replacement: passo 6, immagine 1 di 2 HTC SMT 6175 Keyboard Replacement: passo 6, immagine 2 di 2
    • Remove the top screw.
    • Be CAREFUL, because the LCD screen is attached to the front side of the motherboard by a flexible ribbon cable.
  7. HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: passo 7, immagine 1 di 3 HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: passo 7, immagine 2 di 3 HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: passo 7, immagine 3 di 3
    • Pull the plastic keyboard away from the front case.
  8. HTC SMT 6175 Keyboard Replacement, Navigation Keys: passo 8, immagine 1 di 3 HTC SMT 6175 Keyboard Replacement, Navigation Keys: passo 8, immagine 2 di 3 HTC SMT 6175 Keyboard Replacement, Navigation Keys: passo 8, immagine 3 di 3
    • To remove the navigation keys on the front of the phone, remove the four screws securing the navigation keys using a Phillips screwdriver.
    • Remove the navigation keys from the front of the phone.
    • They should pop out as a unit.
Conclusione
Luke Plewa
Membro da: 04/22/11
116 Reputazione
4 Guide realizzate
Cal Poly, Team 25-29, Garner Spring 2011 Membro di Cal Poly, Team 25-29, Garner Spring 2011
CPSU-GARNER-S11S25G29
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,665
