Parti
Nessuna parte richiesta.
Flip the phone over to have the rear cover facing up.
  • Flip the phone over to have the rear cover facing up.
    • The camera lens should be towards the top of the phone.
Aggiungi Commento
Slide the cover up, towards the top of phone, to unlock the battery cover. Lift the cover off phone and remove it.
  • Slide the cover up, towards the top of phone, to unlock the battery cover.
  • Lift the cover off phone and remove it.
Aggiungi Commento
Use your finger to push the top of the battery downwards and lift the battery out of the phone. Use your finger to push the top of the battery downwards and lift the battery out of the phone. Use your finger to push the top of the battery downwards and lift the battery out of the phone.
  • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
Aggiungi Commento
Remove the six Torx #5 screws that are securing the rear frame. Remove the six Torx #5 screws that are securing the rear frame. Remove the six Torx #5 screws that are securing the rear frame.
  • Remove the six Torx #5 screws that are securing the rear frame.
Aggiungi Commento
Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool. A plastic card can be used instead of the plastic opening tool. A plastic card can be used instead of the plastic opening tool.
  • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
    • A plastic card can be used instead of the plastic opening tool.
Aggiungi Commento
Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone. Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
  • Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
Aggiungi Commento
Pry the motherboard away from the front of the plastic case using a plastic opening tool. Be careful not to break the ribbon cable when prying away the motherboard.
  • Pry the motherboard away from the front of the plastic case using a plastic opening tool.
    • Be careful not to break the ribbon cable when prying away the motherboard.
Aggiungi Commento
Remove the plastic cover from the LCD display and the motherboard. The Motherboard and the LCD are still attached together. The Motherboard and the LCD are still attached together.
  • Remove the plastic cover from the LCD display and the motherboard.
    • The Motherboard and the LCD are still attached together.
Aggiungi Commento
Remove the gray tape securing the ribbon cable. Remove the gray tape securing the ribbon cable.
  • Remove the gray tape securing the ribbon cable.
Aggiungi Commento
Remove the yellow tape securing the connector lock.
  • Remove the yellow tape securing the connector lock.
Aggiungi Commento
Carefully lift the black lock to release the ribbon cable, using the plastic opening tool. Carefully lift the black lock to release the ribbon cable, using the plastic opening tool.
  • Carefully lift the black lock to release the ribbon cable, using the plastic opening tool.
Aggiungi Commento
Pull the ribbon cable upwards, disconnecting it from the Motherboard.
  • Pull the ribbon cable upwards, disconnecting it from the Motherboard.
Aggiungi Commento
Lift the Motherboard away from the LCD display.
  • Lift the Motherboard away from the LCD display.
Aggiungi Commento
Lift off main keyboard from front plastic case using plastic opening tool. Lift off main keyboard from front plastic case using plastic opening tool.
  • Lift off main keyboard from front plastic case using plastic opening tool.
Aggiungi Commento
Remove four Phillips #00 screws securing function keys. Remove four Phillips #00 screws securing function keys.
  • Remove four Phillips #00 screws securing function keys.
Aggiungi Commento
Pop keys out by pushing keys from back of the phone. Pop keys out by pushing keys from back of the phone.
  • Pop keys out by pushing keys from back of the phone.
Aggiungi Commento
Conclusione
Marco Jokada
Membro da: 28/04/2011
247 Reputazione
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,656
