Introduzione
Before proceeding to fix the Sim Card tray, make sure the issue regarding the sim card detection isn't due to a faulty sim card.
Strumenti
Parti
Nessuna parte richiesta.
Insert a safety pin or other small object in the small opening next to the SIM card slot to remove the SIM card.
  • Insert a safety pin or other small object in the small opening next to the SIM card slot to remove the SIM card.
    • The Sim Card Slot is located at the top of the rear panel.
Aggiungi Commento
Cut a piece of tape/ paper approximately the size of your Sim Card and secure it to the back side of the Sim. Be sure to trim any excess.
  • Cut a piece of tape/ paper approximately the size of your Sim Card and secure it to the back side of the Sim. Be sure to trim any excess.
    • It's important that you place the tape on the back side of the Sim Card as it will block the communication with the device if placed on the front side
  • Slowly slide the Sim Card tray back into the device. It should be a smooth transition, don't force the tray in.
  • If the tray is still loose you can keep adding tape/paper until it's no longer loose.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Blain Abebe
Membro da: 22/09/2014
730 Reputazione
3 Guide realizzate
USF Tampa, Team 4-3, Brown Fall 2014 Membro di USF Tampa, Team 4-3, Brown Fall 2014
USFT-BROWN-F14S4G3
3 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 84
Tutti i Tempi: 5,474
