Salta al contenuto principale
HTC One X Plus Battery Replacement
Cosa ti serve
  1. HTC One X Plus Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro SIM card holder to remove it.
    • The SIM card slot is located on the top edge of the device.
  2. HTC One X Plus Battery Replacement: passo 2, immagine 1 di 3 HTC One X Plus Battery Replacement: passo 2, immagine 2 di 3 HTC One X Plus Battery Replacement: passo 2, immagine 3 di 3
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached use the suction cup tool to remove the screen completely from the black casing.
  3. HTC One X Plus Battery Replacement: passo 3, immagine 1 di 3 HTC One X Plus Battery Replacement: passo 3, immagine 2 di 3 HTC One X Plus Battery Replacement: passo 3, immagine 3 di 3
    • Remove the five 2.4mm screws using a Phillips head screw driver and then remove the plastic cover.
  4. HTC One X Plus Battery Replacement: passo 4, immagine 1 di 3 HTC One X Plus Battery Replacement: passo 4, immagine 2 di 3 HTC One X Plus Battery Replacement: passo 4, immagine 3 di 3
    • Remove the two 3.4 mm JIS #000 screws from the PCB board.
    • Remove the PCB board and antenna.
  5. HTC One X Plus Battery Replacement: passo 5, immagine 1 di 2 HTC One X Plus Battery Replacement: passo 5, immagine 2 di 2
    • Use tweezers to disconnect the power button flex cable.
    • Disconnect the touch screen flex cable
  6. HTC One X Plus Battery Replacement: passo 6, immagine 1 di 3 HTC One X Plus Battery Replacement: passo 6, immagine 2 di 3 HTC One X Plus Battery Replacement: passo 6, immagine 3 di 3
    • Disconnect the battery from the logic board by detaching the six pin connector.
    • Remove the battery by pulling upwards.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 3-3, Eyestone Fall 2015 Membro di USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 9
Tutti i Tempi: 4,063
